Omega Help Area => Omega General Help => Topic started by: Mr Skrunts on 10 January 2011, 15:41:36
Title: Water Pumps (Again)
Post by: Mr Skrunts on 10 January 2011, 15:41:36
Just gor a quote off the local garage to fir me a water pump.
They quote me 2.5 hours labour to do it.  £120 inc vat.
Surely thats seems OTT
What tools do I need?
Title: Re: Water Pumps (Again)
Post by: Kevin Wood on 10 January 2011, 15:53:38
Only need the basic Omega tools to do it. Socket set including some TORX sockets. Spanners, pliers for the hose clips. That's about it IIRC.
5 litres of antifreeze to refill it.
Worth checking the state of the aux. belt and tensioner and replacing if worn. If reusing, prise the seal away from the aux. tensioner bearing and pack it with a little grease as they do tend to dry out.
You'll need to remove the multiram ducting and SAI pipework, PAS, Crank and water pump pullies, aux. belt tensioner and cam belt cover to get access.
Post by: duggs on 10 January 2011, 17:42:25
AND ensure it's a VX wasser pumpen only.
Most clones will NOT last, I got through two non VX pumps inside 4 weeks before I insisted the mechanic used a genuine VX one.  Never had a problem since.
Post by: Elite Pete on 10 January 2011, 21:15:56
I've never had any problems with the ones supplied by buypartsby and i've had quite a few of them ;)
Post by: Welung666 on 10 January 2011, 21:17:47
I use FirstLine pumps from my local factors. At least they have metal impellers unlike a majority of the Vx ones I've seen fail for exactly that reason.
Post by: Mr Skrunts on 10 January 2011, 21:38:39
How much are the Vx water pumps on TC these days.
