Omega Help Area => Omega General Help => Topic started by: ajay_2.2dti on 11 January 2011, 20:50:09
At idlering no vibration, but when i drive down the road at low revs but at a constant speed, it will sort of sway and vibrate
Any noise acompanying it? If so can you work out where from?
no noise, near the gearbox, this is really puzzling me, ive cleaned the maf sensor and egr valve, it feels almost like a misfire, but it aint :o
Check the condition of the gearbox mounts, rubber donuts at both ends of the prop (including bolt tightness) and the centre prop bearing for any play.
this might seem daft but check your wheel nuts are secure , just when you mention sway im thinking a loose wheel or bearing?
oops, DMF anyone?
thanks fella's, ill check those...
DMF lol i hope not... :(
oops, DMF anyone?
Depends really on whether it happens only when coming off or going on to the clutch when the vibration occours.
i get it in whilst in gear but with a little accerlation, but i have noticed that in rubber boot in the middle of my propshaft has split
On the centre bearing? If so that could be the cause (I.E. the centre bearing has collapsed causing the prop to pull excessively and tear the rubber protector). If you lie underneath the car and hold the prop just in front of the centre bearing check to see if there is any up/down/side to side movement :y
