		Omega Help Area => Omega General Help => Topic started by: SP_3.2 on 25 January 2011, 09:47:12
				Getting this poping up on starting the car only not as i,m driving. I have checked the conections and all seem good. i have removed the front rod on the sensor and moved the arm up and down after a few time the headlight range moves up and down... which i would think would show the the motors are working ok.
 I have also checked the rear sensor and arm and all fine.Anywhere else to check or is it Tech 2 time.
 Thank
 Steve.
				prob tech2 and see whats its complaining about is easier than stabbing in the dark  :y
 ;D ;D and it is, never get time in the day to have a good look so it,s me with a light in the dark which is anytime after 5pm
				If it's still operating as intended, it's possible that the wiring has chafed under the front wing and brought up the warning falsely.
 I've seen a couple of cars with the warning on the MID but where the ECU is happy after a chat with a Tech 2. If there's a real problem the lights will normally dip fully.
