Omega Help Area => Omega General Help => Topic started by: ber5ien on 30 January 2011, 11:41:36
Hi,
I managed to read the codes from my omega 2.2 petrol b fl 2001 180k on the clock! + lpg.
Please see the following codes:
0130 P0130 O2 Sensor 1 Incorrect Signal
0340 P0340 Camshaft Position Sensor Circuit No Signal
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0110 Intake Air Temperature Circuit
All air pipes cleaned new filters new spar plugs.
I have recently disconnected also the O2 sensor so that is why it showed me that as well.
The car take more fuel, 20mpg;/ and having problems during acceleration (power loss) it's not happening always.
I believe that the Cam sensor needs replacing.
Please advice :)
Thanks.
Best Regards
ber5ien
Clear the codes & take it for a short run, then see what codes return :y
Yep cam sensor needs changing ... i would change that first and take it from there .
use genuine Vx only :y
Also you could check for oil in the plug wells
Thx guys. I will check it again.
Cheers.
