Omega Help Area => Omega General Help => Topic started by: Lesopc on 04 February 2011, 11:42:16
Hi guys, me again. Can anyone tell me how to change the Drivers Electric Window Switch as mine is broken (the button itself actually snapped and now i have no operation of the window).
Specifically i would like to know if the wiring for it is soldered or if it is a plug/socket arrangement and how to get the old unit out without damage to the door?
Thanks guys.
Also would it be advisable to fit a Front and Rear 4 Button type instead of the Front only 2 Button type as i might in future try to fit rear electric windows in place of the current manual winders if it would work as i assume the wiring is already there???
On the facelift the whole unit (mirror control, front & rear windows) comes out as one piece.
It can be just popped out, no need to remove door card, but its a bloody tight fit. It can be levered out at the edges, but be careful, there is a clip which is damn stiff.
Loom plug is underneath, so if you can source a replacement from a breakers its just plug new one in and off you go :y
That's what i hoped Tunnie. Thanks
Thanks guys.
Loom not present.........you`ll need the following
Driver`s door loom + obviously switch panel
Both rear door looms
Rear window switches
Rear window motors
30A maxi fuse for top R/H corner of cabin fusebox
Thanks guys.
Rear window motors
Very much help indeed, thanks.
Thanks guys.
Rear window motors
Sounds familular ;D ;D
I have a 4 switch unit here in good working order from a facelift if you need one...
Could you tell me what your asking price would be for said part? many thanks. Les
£15 delivered :y
£15 delivered :y
Hi MutantCav, this is a great price for the said part, just to confirm that this is the one for a facelift miggy? If so i can buy on Fri 11/02. Will also need paypal e-mail if you have one, otherwise need to find another way to pay you. Cheers matey.
Yes I know mate but its sat in my garage doing nowt and has been for some time...yes defo facelift...will send my paypal details by pm now :y
Cheers Chris...recieved.
