Omega Help Area => Omega General Help => Topic started by: robo MV6 on 06 February 2011, 20:19:31
Title: Poor Heating
Post by: robo MV6 on 06 February 2011, 20:19:31
My MV6 face lift 2000 model heating never reaches a sensible temp even when the control is set to high.  I have had the heating pipes looked at by a mechanic who reckons that there is no problem with the matrix and all pipes are hot. The air con works well! :-?
Anyone else had this problem and found a cure?
robo
Title: Re: Poor Heating
Post by: kcl on 06 February 2011, 20:21:20
Does the engine heat up normally? Temp meter raising to the middle of the scale and stays there? If not, you've got a stuck stat.
Post by: robo MV6 on 07 February 2011, 20:45:16
Yes the temp is showing normal range and stays in middle!
