Chat Area => General Discussion Area => Topic started by: theowletman on 21 January 2008, 19:43:50
Sick of misbehaving crank and cam sensors, tired of fault codes and misfires, fed up with oil leaks ? Have a look at this and imagine an Omega with one of these in, turn the sound up or use headphones, sit back and listen to the music.
http://www.youtube.com/watch?v=Eo-9Io41bt8
Imagine.................James could see what mpg he could get out of that........... ;D ;D ;D ;D ;D
Sounds good but I'm sure I detected a slight missfire ;)
sounds good !!! :y get that manifold glowing :o
No, ;D ;D ;D that was a fly caught in the foo foo valve...
do you think it would run as well on LPG ;D
that manifold could heat a house for a day the way it was glowing :o
70litres / 100km.
16 gal / 62 miles.
Lots of Shell points though.
Yeah.. See all that fuel that's pi$$ing into the intake trumpets?
I think that's what I'd get fed up with...
Very impressive that it holds together at all though :o
It'd need a rebuild once a week with the mileage most of us do ;D
3.36 MPG to the rest of us :D
No way..How many times I tried..Cant open the link.. :(
You think its safety glass those chaps are sitting behind? Would certainly sting a bit if it lets got and something clips you on the way by...... :D
Hope so.
I saw a 1.8 Rover K series making over 250BHP on a rolling road once.. As it passed through about 8K RPM it occurred to be that I was standing at a tangent to all the rotating parts so I relocated myself behind the car :o
Couple of weeks later at a track the scavenge pump belt came off, went into the cam belt and all hell broke loose. Bye bye K series :'(
I was a Donnington Park in September, they had last years Renault F1 car there .. wired to a computor programme it "played" the National Anthem .. now "God Save Our Gracious Queen" will never ever "sound" the same to me .. :) I was stood no more than 10 feet from it ... the noise was fantastic... :)
http://uk.youtube.com/watch?v=5Eoe8hEzdZ8
they done that on top gear when Hampster tried to drive an F1 Car. They reckon that because the engine is so tight when cold its more or else seized, they have to slowly warm the oil and coolant to 80 oC before they can even think about turning it over
Be no good on a cold day and your late for work would it!
I reckon you'd probably make up the lost time pretty quick once it'd warmed up though. :o
Cam
Go to YOU TUBE and search for renault f1 engine, lots of choices should appear.
This is the message I get when I tried to reach youtube >:( >:(
a real shame
(http://i181.photobucket.com/albums/x80/mecdv6/yasak.jpg)
now I see ..Possibly new
a real shame
Looks like a local problem, rather than a WWW one??
a real shame
yep..they make it forbidden >:(
for my country
I got the exhaust manifold like that on my CArlton 2.2 when the dizzy f***ed up ;)
