		Omega Help Area => Omega General Help => Topic started by: MutantCav on 16 February 2011, 16:08:47
				Can someone please tell me how you remove the pipes running through the bulkhead to the heater matrix?? Specifically the quick release valve thingies...
				push or pull clip until it clicks then persude the hose off
				Pull the furthest end of the pipe towards you so it clicks, theres 2 clips you have to depress to make this happen, then twist back and forth to remove pipe from bulkhead, worth putting a little grease or vaseline on the ends of the metal pipes after removal to aid refitting... Pig of a job to get them off first time but once you've done it, it gets easier.
				Thanks lads...didnt want to break anything...will practice on the breaker first though lol
				maint guides are your friend ;)
 http://www.omegaowners.com/forum/YaBB.pl?num=1185891036
				Thanks Jimbob :y I didnt think there would be a maint guide for something so supposedly simple...but then I have stripped many Omega and had to ask so it makes sense...good ol' OOF :y
