Omega Help Area => Omega General Help => Topic started by: griffin on 19 February 2011, 17:25:08
Title: Life of oil
Post by: griffin on 19 February 2011, 17:25:08
Hi ALL
Very simple question, is there a shelf life to Vx oils.
Cheers
Title: Re: Life of oil
Post by: hotel21 on 19 February 2011, 17:30:23
Would say the simple answer is, no different to other oils?  As long as it is in a sealed container and stored correctly as regards temperature, humidity etc, that is....    :-/
Post by: griffin on 19 February 2011, 17:32:38
Thats what concerns me its in original sealed container but has been stored in my shed for the last 8-9 months during the very cold weather  :-/
Post by: hotel21 on 19 February 2011, 17:35:59
Given that it is sealed then the airspace in the container is minimal so would suggest that moisture ingress should not be a problem.
As to temperature cycles and fluctuations dont think it should make much odds.  Perhaps the olive oil/honey scenario where solids form due to low temps but go again when temperature rises.
That said, google would be your friend or perhaps some specialist oil companies Q & A?
Post by: griffin on 19 February 2011, 17:37:35
Thanks for the advice I'll have a search.
Cheers  :y
Post by: joff on 19 February 2011, 19:53:51
Oil in your car has been in same temp do you worry about that when it's -15 outside. Only 8-9 mths that's nothing bet your shed never got below -10 or so that should be fine there more H2O in your engine oil.
Post by: Varche on 19 February 2011, 20:44:24
Did someone mention olive oil - I'm your man. ;D ;D
Post by: Entwood on 19 February 2011, 20:54:30
You're really Popeye ???  :)
