Omega Help Area => Omega General Help => Topic started by: rob69 on 19 February 2011, 22:23:30
goes up and down with motor ok but when you retract it the blind seems to just fold onto the parcel shelf im guessing the retracing spring mechanism has broke or come apart is this common how do i fix it i looked at trying to take it out but couldnt work out how to get at it any info????
Remove the rear shelf http://www.omegaowners.com/forum/YaBB.pl?num=1152745304/0
I have the same problem on one of mine, the other one just clicks and does nothing - the gear mechanism is fubar, got a replacement from a breakers.
As suggested follow the guide, it is spot on. The problem I had was getting the shelf out past the Bose speakers, IIRC the studs which go through into the boot space tend to catch on them. A good yank works but mind you do not damage the speakers!
If you manage to fix it any chance you could let me/the forum know how? :y
I went through the same stage with mine. I removed it all from the car & manually wound it up & down OK but didn't seem to achieve anything. It sorted itself when the weather warmed up. I don't think the fabric is pliable enough when cold. :-/ :-/
Stray glue from fitting the rear screen made my parcel shelf a right barsteward to remove. :-? :-?
Mine was sticking like that at the end of last summer. All I did was squirt some of the old faithful, WD40, down the sides of the mechanism and then keep raising and lowering the blind a few times. It worked a treat with the blind now folding down as it should :y :y
Mine just gets left up. It's only when SWMBO drives it that it gets lowered ............. same with the Senator, but they weren't electric. ;)
