Omega Help Area => Omega General Help => Topic started by: MikeDon on 23 February 2011, 11:51:35
Hi guys,
Which coil/dis pack is the correct one for a 2001 3.0 elite?
Been on Eurocarparts and there are 5 different ones :-/
Need to keep car on road so don't want to be taking stuff apart twice and had a look to see if I could see a part number.... which I now know was obviously a waste of time!
They (Eurocar) seem to distinguish between an estate and a saloon too, are there different coils on them?
Thanks, Mike
as a rule, i think the differance between the 2.5 / 3 ltr v6's is the shape of the plug on the LT side :y
you will find that the plug on the end of the MAF sensor ( pipe that comes from the airbox ) is the same shape as your coil pack :y
some have square corners or some have ovel shaped conectors :y
engine is a engine ;)
no diffferance between saloon and estate :y
thanks, that will save a bit of time then... will take a look at that when I get home....
Strange that eurocarparts list some for estate and others for saloon?! ::)
