Omega Help Area => Omega General Help => Topic started by: amba on 24 February 2011, 20:57:51
Title: What would be the effect ?
Post by: amba on 24 February 2011, 20:57:51
Just for curiousity as I ahve a slight issue with the air connections on my rear self levelling shocks I ahve disconnected fuse 27 to dissable the pump.
What would be the detrimental effect...if any..of using s/l shocks without the air going into them.
Title: Re: What would be the effect ?
Post by: Andy H on 24 February 2011, 21:08:05
If you don't tow a caravan or fill the boot with tools or travel '5 up' I doubt you will even notice.  :y
If you do then you will ground the exhausts over speed humps.  :(
Post by: amba on 24 February 2011, 21:12:49
Thanks Andy H..just wanted to put my mind at rest until I can fix the air leak.
Boot is full of work stuff but no bottoming out on drive home tonight
