Omega Help Area => Omega General Help => Topic started by: downsmen on 05 March 2011, 13:01:05
Hi Just changed the Dispack and now the car is running worse then before.
Any Ideas just done paperclip test
Results as follows
12
57
31
any ideas
what do you mean worse than before?
Are you sure you plugged the leads back in the right order?
Hi just found a lead i had not plugged in
All better now
Thanks :y
If only every problem on a miggie was as easy to fix! ::)
