		Omega Help Area => Omega General Help => Topic started by: tunnie on 20 March 2011, 15:59:24
				Treated the 2.2 to a wash today, first time in about 9 months  ::)
 Its having its revenge by blowing fuse 15, first time thought it was the climate, as I kept switching from Off to Auto, as I don't think the compressor was running. It stalled, no dash lights (although climate and radio still had power)
 It stalled again at the tip, only stopped for around 15 seconds  :( - So I began to think it was the fans.
 Got home, stopped for around 30 seconds, temp rose to 90, usually sits on 85, just after 90 heard the fans start, the car spluttered a bit and stalled again.
 Popped the bonnet and the cooling fan was running, and switched off shortly after.
 Luckly I had a fairly good supply of fuses on board, but bit stumped why it keeps blowing  :-/
 Any ideas?
				Just done a test, it's not the fans. It's the climate as I first thought. Unplugged the main fan, went for a spin. Got back, let car idling for ages, let temp creep up to 90. It was fine, start turning the climate off and on, few seconds later cut out.
 Doing another test now, climate off, engine idling. It ran ok, then the fans clicked on, still fine! Think my compressor is fubared! :(
				agreed, sounds like the motor is drawing to much current,
 cant complain really its been reliable for you up to now?
 Can't complain at-all its the first thing thats failed on it in years! I replaced the coil back about 2 years ago, that did not fail, it was just starting too.
 Only thing thats ever really failed on it was cam sensor about 4 years go!
 Oh a spark plug went, but it had done about a million miles  ::)
 And the exhaust flexi but thats it  :)
 One question is there a fuse just for the compressor in the engine bay? Would like to just unplug it for now
 Don`t think so. When my comp. packed in the fuse never blew when I tried switching A/C on. Easiest way to disable....disconnect multi-plug on comp
 Was thinking that. I know its not engaging because all the climate pipework in front of the aux belt area is hot, not cold...
 The pressure must be too low causing it to not engage right as I've spotted some green dye about, and around the compressor.
 It should just not kick in though, not blow the fuse  :-/
				Even though the comp may be knackered, to check whether it`s blowing the fuse, disconnect plug from it then switch climate on, see what happens with the fuse
 Good idea, my little job for tommorow morning  :)
 Compressor is passenger side iiic!
 Yep, you should be able to slide under without a jack ;D
 I can do an oil change without one  :D
 So I`ve heard.....hence my comment ;D ;D
				Have you proved its not the cabin fan and/or its speed controller?
 Knowing how much leaves your car gets cover in, its likely the scuttle drain has blocked at some point...
 Its never been blocked, only today I popped the cover open, perfectly clear and I blasted the hose through it!
 I'll know more tomorrow when I disconnect the compressor...
				ok, now this is getting very, very odd! I now think its the earth to the car.
 Disconnected the Compressor.
 Started the car, with the door open, within a few seconds, the fuse blew but the car kepts running, it was miss-firing, with the brake light & battery light flashing in turn :-?  :-/
 Popped a new fuse in, started, same happend.
 So began to think was it related to LPG? Turned that off, started, all ok. Start messing with the climate control, Auto to Off over a dozen times, all is good! Got it me thinks, so went inside house (engine running) grab my wallet (mother T  ::)  ;D) - As the petrol light was on  ::)
 Get climb in, go to close the door and, bang, it cuts out again! This time (while on petrol) it did not miss-fire, but dash lights, rev couter ect all gone. But climate, radio, door lights still have power.
 So not LPG me things, put it back on LPG, engine idling, again mess around with climate fan controls, all ok. Then few minutes later of just idling, just as I go to grab the door again!
 I did wash the door sills, wondered of possibly the light in the door could cause it? Popped it out anyway, still cut out!
 So bit stumped.... thinking earth to the car (as only thing thats changed is I washed the bloody thing!)
 Where is the earth in the engine bay?
				Does it blow with Eco on? Also imagine compressor has a relay, ratherthan direct drive from climate panel
 Did not try it with Eco, just kept flicking between Auto & Off while running on both fuels.
 Is there a relay I can pull in the engine bay just for the compressor?
				Could the pressure in the air-con be just at the level or below the compressor needs, and it keeps attemping to turn on? Hence it appears to be a bit random?  :-/
 K60....green......5th one back from front of relay box
 Going to unplug it now  :y
				Ok, thats not it  :(
 Removed the relay, started, climate set to Auto & Eco.
 Ran ok, clicked over to LPG fine.
 Door open fully, went to grab it, started to close it a fraction, heard a click and it cut out.  :-?
 Too many times its done that, earlier on, mother T jumped in, I then got in to drive, went to grab the door, and again go to close the door it cuts out  :o  :-?
 Bulb is removed in the door, but its not getting anywhere near close enough to press the button in the frame  :-/
				Its not the earth, this looks like it to me?
 (http://dl.dropbox.com/u/803897/Omega/Misc/Photo%20Mar%2021%2C%2011%2010%2056.jpg)
 Checked that was done up, as a couple of times, getting in the car, made it cut out  :-? was wondering if somehow that was loose. Its all ok, bounced far around again all ok. Then cut out again without me doing anything. Climate was on and set to Eco....
 Looks like the fat man is right again, annoyingly! Fan speed controller? - Scuttle never been blocked (least in my ownership) - But, when washing it yesterday, I did stick the hose down the scuttle drain, pollen area and give it a damn good blast with the hose to make sure its clear. Always used to do that when giving it a good clean  :(  :-/
 I've checked the book of b0lox for a fan controller fuse/relay, multiple references to air-con blower and heater control unit.
 Is there a single fuse/relay for the fan controller?
				30A green maxi....top L/H of cabin fuse box.
 Question........are you sat in the driver`s seat whenever the fuse blows?
 Cheers Rob  :y
 Yes, its never blown/cut out when I am not sat in the car. Infact I left it idling for about 15 minutes while I helped next door with their Pug 106....
 Mines a poverty spec, so no leccy seats, unless your thinking bum warmer? (i never use them)
 Cheers Rob  :y
 http://www.omegaowners.com/forum/YaBB.pl?num=1269801448
 Check all other fuses....especially #14
 Cheers Rob  :y
 Ooooo, that looks very interesting.....
 Off to go inspect...  :)
				ok, now this is getting very, very odd! I now think its the earth to the car.Disconnected the Compressor.
 Get yourself some 25mm cable, a long spike and a hammer then.
 It wont make any odds but, you will at least have an earth on the car.  ;D
 Does not sound ground related to me, you need to find where you got water to that you shouldn't.
				I'm wondering if the washing of the car was just bad timing, going on Robs suggestion above, I checked the wiring to the heated seat. I could see where it would rub, but nothing stood out (as in bare wires)
 I pulled fuse 14 in the cabin, hoping that might disable it, as fuse diagram suggests its linked to 15?
 Still did it, but I was seated at the time.
 So got out, put another new fuse in about my 15th  ;D - Engine idling, i stood on the sill, then with my foot, I bounced up and down on the edge of the seat. When I got to the middle, it cut out! Just where the heated seat wiring is.....
 Now as I mentioned above, nothing clear stood out that could be causing the short. What if.... (tunnie bodge warning.....) I just cut both of the black wires which go into the bottom of the seat? - Tie them up, insulate them and put them out of the way....
 Even in our ultra cold winter, I find I never use bum warmers on cloth seats.....
 Sounds like the problem....disable the heater with a "Tunnie Bodge"
				A "tunnie bodge" has been implemented, and its fixed  :D
 Cheers Rob for posting that link, I would never have thought to look at the seats!  :y
