Omega Help Area => Omega General Help => Topic started by: Omega Man on 25 March 2011, 20:36:34
Can the door handles on the inside be removed for spraying or do they have to be done on the door pannel? :-/ Half the paint has alraedy come off :(
Door card off. You`ll see rows of welded plastic studs Drill spreaded head of stud with a 12mm bit (carefully). Refit using 6mm self-tappers with built-in washer behind head
Thanks Ill give it a go :y
