Omega Help Area => Omega General Help => Topic started by: cannonfodder on 28 March 2011, 21:39:39
Title: metallic 'rattle' on pull off
Post by: cannonfodder on 28 March 2011, 21:39:39
have this annoying rattle on pull off, if i didnt know better, it sounds to me like a heat shield or something rattling. It only does this occasionally, did it again today, the rattle, which can only be described as a metallic rattle, starts off on pull off, it dissapears after the revs pick up, maybe 1000, then returns again with low revs, dissapears when its warmed up. Any ideas guys?
Title: Re: metallic 'rattle' on pull off
Post by: harpersimon on 28 March 2011, 22:03:14
have you checked the heat sheilds..
Post by: MutantCav on 28 March 2011, 22:11:44
Prime suspect I would say would be the heat shields on the cat/s coming loose...or the exhaust system...
Post by: cannonfodder on 28 March 2011, 22:35:04
well the last thing done on the car was a new cat, heared on here the other day about a timing chain rattle, wasnt sure if this wa the same?
as always thanks in advance
Post by: henryd on 28 March 2011, 22:39:41
no timing chain on the 2.0,timing belt :y
Post by: cannonfodder on 28 March 2011, 22:41:32
thanks henryd, was havin kittens there :y
Post by: albitz on 28 March 2011, 23:30:35
Almost certainly a heat shield imo. Nothing to worry about really, but can be irritating. :y
