Omega Help Area => Omega General Help => Topic started by: Mart280 on 23 March 2011, 20:51:15
Title: Question about Omega key
Post by: Mart280 on 23 March 2011, 20:51:15
I have had my Omega nearly two months now and realized I had never unlocked the car by putting the key in the door as opposed to just pressing the button, however when I put the key in the door nothing happens, it wont let me turn the key left or right, am I doing something wrong ? I only have one key and am worried if the battery goes I wont be able to get into the car.
Title: Re: Question about Omega key
Post by: Entwood on 23 March 2011, 20:55:33
Turn the key to the right (clockwise) slowly but firmly, it will "feel" as if the key wants to snap !!
At the same time try and open the door.
Do NOT expect the door "pin" to rise as it usually does when unlocking.
The door will open but it takes a bit of force and conviction !!! If the alarm is set it WILL go off !! key in ignition and switch on to cancel.
Post by: Andy B on 23 March 2011, 20:59:28
isn't that the answer to .......'my battery is flat & I can't get into my car' ? :-/     ::) ::) ::) ;)
The door pin will go up even when unlocked with the key in the door because the micro-switches inside the door will operate the central locking.
Post by: Andy B on 23 March 2011, 21:01:18
lubricate the lock, it'll not have been used with the key for yonks.  :y :y :y
assuming the key & barrel match  ;)
Post by: Mart280 on 23 March 2011, 21:31:15
Thanks for the help guys, I will try some of the suggestions in the morning.
Post by: Vamps on 23 March 2011, 22:16:28
I have the same problem, so far I have not had the courage to 'force' it..... ::) ::) ::)
Post by: 05omegav6 on 23 March 2011, 22:22:47
Go on, you know you want to :y
I was quite surprised by just how much force is needed. Turn it until you think it'll break, then turn it some more.
Mine didn't, battery was pancaked though. ::)
Post by: Entwood on 23 March 2011, 22:38:47
As I understand it Andy .. if you use the key in the lock with a working battery, you don't actually "use" the key .. if that makes sense ... the first part of the turn makes an electrical contact that triggers the central locking to unlock all doors .. same as the remote.
My thought was that, given the description by the OP, the electrical contact is not being made, so the "manual" open might work. I also agree that the lock might just be siezed !!
Post by: Andy B on 23 March 2011, 22:42:47
.... if you use the key in the lock with a working battery, you don't actually "use" the key .. if that makes sense ...  .....
Perfect sense Nige  :y That's what I meant re the micro-switches on the door locks that operate the central locking system.  ;) ;)
Post by: Mart280 on 29 March 2011, 10:12:50
Guys I still cant unlock my car using the key, I really dont want to force it too much, my car battery is fine, I want to get another battery for my key fob so I have back up, is this battery ok  http://www.buyabattery.co.uk/duracell-cr2032-battery-3v-lithium-dl2032-2032-batteries-p-1475.html
Post by: RobG on 29 March 2011, 10:38:06
Yep :y
Post by: Mart280 on 29 March 2011, 10:56:49
Thanks
Post by: zirk on 29 March 2011, 13:48:59
From my experience (Facelift) if the door has been dead lock using the Fob then the button wont come up (flat battery mode) but if it was previously dead lock with the Key only then it does pop up.
