Omega Help Area => Omega General Help => Topic started by: bigegg on 31 March 2011, 12:51:59
I replaced the ABS ecu, and now my cruise control doesn't work.
(TBH, it might not have worked before - but I was told it did!)
Is the cruise control controlled by the ABS ecu, so might just need activating via tech2?
or am I likely to have another problem?
I've had a look at previous threads re. cruise problems, and I can't see any obvious problems (like cable disconnected etc)
The only part the ABS plays is providing a speed signal.
So if the speedo is working then its not the ABS at fault.
Hmmmm, the 2 cars in the last week showing the same issue after an ABS ECU replacement...
...hoping to look at terberts one this weekend or Monday, see if I can find out what/why/how/if/when ;D
It could be a red herring.
I'm not definite that the cruise control on mine ever worked.
I know it's got the winter pack AND the cruise fitted, which elitepete says was never standard.
So it's possible someone has retro-fitted it, and never activated it.
IIRC the cable from the cruise to the throttle bodies was quite bent due to the location of the cruise control
but it's not even attempting to cruise :(
