Omega Help Area => Omega General Help => Topic started by: immortal on 06 April 2011, 11:52:00
Title: Blew SAi AGAIN
Post by: immortal on 06 April 2011, 11:52:00
Hi,
Blew my SAI pipe again.Had to order one in from Vx and wait 4 days last time. Anybody know where would stock one in today?
Or would black electrical tape do the job?
Matt
Title: Re: Blew SAi AGAIN
Post by: Marks DTM Calib on 06 April 2011, 11:54:02
If its the small rubber pipes then its blowing for a reason.....either a centre exhaust section or a cat is blocked.
Post by: immortal on 06 April 2011, 11:56:47
Hi,
Yeah i think it is the cat blocked. How would i repair it temporary? It has only blew as i have just been down the motorway and gave it a bit of a thrash. Felt very quick and was easily flying past 80 70ish
Matt
Post by: Marks DTM Calib on 06 April 2011, 11:58:39
No easy way as the pressure is causing hot gases to pass through the pipe (which would not normaly happen).
Post by: immortal on 06 April 2011, 11:59:48
If if found a pipe of the same diameter but not as thick , that would fix it for a few days if i drove steady wouldnt it whilst i wait for a new one from Vx?
Matt
Post by: tigers_gonads on 06 April 2011, 14:29:00
can't you remove the sai bits ?
i thought dlk did something like that to mine when he did my belts  :-/
Post by: Kevin Wood on 06 April 2011, 14:35:09
Yes, you can remove the whole SAI system and block the feeds to the manifolds with no ill effects at all. (as long as you leave some load on the solenoid output of the ECU)
But... Where would the gases from the blocked exhaust go then? ;)
The SAI problems are the symptom here.
Post by: immortal on 06 April 2011, 14:39:08
If i paid for a straight through stainless exhaust minus the cats would it fail its mot then?
Matt
Post by: Kevin Wood on 06 April 2011, 14:41:58
Matt
Yes, it needs cats to meet the MOT emissions limits.
