Omega Help Area => Omega General Help => Topic started by: Raymienets on 13 April 2011, 11:35:56
Title: Miggy specialists / enthusiasts
Post by: Raymienets on 13 April 2011, 11:35:56
A few weeks ago I had the code P0743 which I was informed was the solonoid or the torque converter. Being advised to try the cheaper option and replace the solonoid I did to the cost of about £120 including New ATF fluid and gaskets plus the solonoid. Now having put it all back together the code still not clearing. Any advice if I picked the wrong option which I think I have and need the torque converter changed should I just try and get a second hand gearbox and as asked before how difficult is it to replace.
Title: Re: Miggy specialists / enthusiasts
Post by: feeutfo on 13 April 2011, 11:48:36
P0743 Torque Converter Clutch Circuit Electrical.        According to the last I have.
By "not clearing" do you mean not clearing with a code reader? Or is it not clearing itself?
If cleared with a code reader and it still returns then the code is current and not historic......?
Post by: feeutfo on 13 April 2011, 11:50:06
Cam sensor is known to upset 4 pot auto boxes.
Post by: Raymienets on 13 April 2011, 11:53:44
The code reader I have although a cheap one wont clear the code.
Post by: Lazydocker on 13 April 2011, 11:54:15
Hmmm... Apart from the torque issue when chipping oil burners the auto boxes are normally pretty reliable :-/ :-/
As Chris says, cam sensor is known to throw up all sorts of strange problems with 4 pots
Post by: Raymienets on 13 April 2011, 11:54:45
Surely it would'nt throw up a P0743 code.
Post by: feeutfo on 13 April 2011, 11:58:21
It can throw up a hat full of auto box codes... Have you checked for engine codes?
Failing that a wiring issue?
Post by: feeutfo on 13 April 2011, 12:00:17
Ps, need to see that code cleared and see if it returns, ultimately. Are you near any of the tech2 owners on here.
Hotel 21 is nearest you.
Post by: davethediver on 13 April 2011, 15:35:41
When my Cam sensor went I had all sorts of random gearbox codes come up. Changed sensor and hey presto no more problems with strange codes :y
Post by: TheBoy on 13 April 2011, 19:10:31
Cam Sensor does through a gearbox code, but not that one.
I would suggest the diags were poor.
The TC itself if normally mega reliable - never heard of one failing.
