Omega Help Area => Omega General Help => Topic started by: raywilb on 06 May 2011, 19:54:18
Title: brake pad warning
Post by: raywilb on 06 May 2011, 19:54:18
brakes were checked out after a brake pad warning appearred and deemed to be ok, yet warning is still on. complete new, discs, pads, shoes rear 4 mths ago. front pads have been on 18 mths but are hardly worn, could it be a sensor,? :-/
Title: Re: brake pad warning
Post by: dbug on 06 May 2011, 19:57:35
Could be - try unplugging one at a time and shorting out pins in socket to check sensors.
Post by: raywilb on 06 May 2011, 20:09:57
afterthought , i replaced the rear springs not so long ago & i wonder if i over stretched a wire.  :-/ .
Post by: CaptainZok on 06 May 2011, 20:14:33
No pad sensors on the rear, just two on the front of yours Ray.
Post by: fiend61 on 06 May 2011, 22:45:01
more than likely a duff or broken sensor  :y
do as suggested and unplug each sensor in turn and short out the pins you will then know whether it is just one sensor or both  :y
Post by: Andy B on 06 May 2011, 22:48:27
you get a pretty good idea if it's goosed just by looking at it.  ;)
