Omega Help Area => Omega General Help => Topic started by: steviehp1 on 06 March 2011, 13:00:45
Title: auto box ecu upgrade to v9?
Post by: steviehp1 on 06 March 2011, 13:00:45
hi there, can anyone tell me if there is a place in or around sheffield where i can get my box ecu version checked and if nec up graded?
i have problem of box sticking in 1st (randomly) untill revs of 4000 rpm reached, if sport button pressed it changes up as normal. any help please.
Title: Re: auto box ecu upgrade to v9?
Post by: TheBoy on 06 March 2011, 13:02:22
Its likely version 0A is the latest for your 2.2
As a first port of call, I'd check the ATF levels.
Post by: ffcgary1 on 06 March 2011, 15:03:48
1st to 2nd solonoid might be playing up but as stated check the atf level on level ground and hot. :y
Post by: MotormanV6 on 06 March 2011, 18:53:06
Hi there, I recently bought my first Omega B, an MV6 ('99 mini face-lift)on which the transmission changes are perfect 'round the houses'. However I took in on a decent run on fastish A roads & what happens is, it makes unnecessary changes up & down between 3/4 & 4/3 at about 48/50 mph. (Sort of 'hunts')
Looking on the forum I'd assume this is due to the fact that I have the early version of the ECU's sofware, so how do I go about getting it flash upgraded to the later version (V9). I'm in S.E London/Kent. (Orpington).  :)
Post by: TheBoy on 06 March 2011, 19:02:56
Suspect yours is on V5, you'll have a GS820 TCM, V9 is the latest for your combo.
Either http://theboy.omegaowners.com or a dealer.
Post by: MotormanV6 on 11 March 2011, 18:23:44
Thanks for that, I took it to W.J.King (Main Vauxhall Dealers) today & like you said, they confirmed it was running V5, and they've now updated the software to V9, they charged £39 + vat which seemed reasonable.
Took it for a long test drive......it's like driving a different car...superb! Thanks for your advice.
Post by: Malcolm_D on 11 March 2011, 22:22:27
Sounds very reasonable! I think I may contact my local stealer and enquire about my 02 plate 2.6 Elite.....Evans Halshaw in York or do I go to Walkers in Selby? Can anyone make a recommendation?
EH quoted me £500 ish to replace an aircon pipe when it was only the schraeder valve which needed changing, plus they don't accept the OOF trade card, Walkers, on the other hand do accept the card and come across as very 'user friendly'.  :-/ :-/
Post by: TheBoy on 12 March 2011, 11:21:10
02 2.6 will have an GS821 ECU, latest firmware for GS821 coupled to a V6 is v8
Post by: steviehp1 on 12 March 2011, 23:56:59
thanks 4 ur help guys, will get oil changed and see if i can find an outlet 4 update.
Post by: Malcolm_D on 13 March 2011, 08:24:20
Thanks for this, I will investigate with the stealers.  :y
Post by: TheBoy on 13 March 2011, 10:31:55
thanks 4 you are help guys, will get oil changed and see if i can find an outlet 4 update.
Didn't understand a word of that ;)
Use English, no text speak which is notoriously difficult to read.
Post by: steviehp1 on 13 March 2011, 23:18:30
sorry was tired when i wrote that...
meant, thanks 4 your help guys blah blah blah... :P
Post by: steviehp1 on 02 April 2011, 01:45:02
Latest...
ive had the filter and gaskets replaced, cost me £110, didnt look or smell that bad really, any way, it runs and changes gear more smoothly but still has not cured the sticking 1st gear problem. will it ease as the fresh fluid gets used or is there another reason? baffled!  :-[ >:(
Post by: feeutfo on 02 April 2011, 02:14:55
Is this from cold? Or all the time?     Not sure if the 2.2 revs higher to warm the cat(s) from cold like the v engines do? Snow mode or sports mode breaks the cycle...?  :-/
Post by: steviehp1 on 02 April 2011, 12:17:02
more so when warm. or if creeping in traffic then setting off, very intermittent.  :-/
Post by: V6 CDX-er on 03 May 2011, 16:07:02
Sheffield here as well  [smiley=vrolijk_26.gif]
I'm another one with the long 1st gear problem. Changing the gearbox oil and filter did little to cure the problem. Added to which when I went to start her this morning my TC light was on and I had little or no drive in 'D'.
IIRC when I changed the autobox oil and filter about 5000 miles ago, I noticed a slight weeping from the bellhousing / torque converter area, so I'm guessing it is running low on fluid. About to go out and check, so will report back with my findings.
Post by: V6 CDX-er on 03 May 2011, 22:50:13
Just as I suspected, the box was low on fluid. Had to put about 1 1/4 litres in it.
Much better now with a smoother shift between 1st & 2nd, but still suffering the long first gear.
Post by: steviehp1 on 08 May 2011, 13:58:47
hi, from a sheffielder lol. i had my filter and ATF changed, made no differance, the old filter and oil didnt look that old, maybe previous owner tried this before delling it to me.
its intermittent, some days rarely have the problem, others its quite regular. doin my head in now. running in sports mode to solve it.  :'(
Post by: Mike R on 13 May 2011, 10:41:28
I'd like to know more about this, a my 2.2 auto, sticks on 2nd gear when warm sometimes. I'd expect it to do it when cold, to warm up all the fluids etc, but when warm!??
Mine stick's 2/3.
