Omega Help Area => Omega General Help => Topic started by: Rayviator on 28 May 2011, 11:06:08
Title: Alarm reset.........?
Post by: Rayviator on 28 May 2011, 11:06:08
Hey guys. After snapping my key I had to wait for a replacement from the dealer. During this wait my battery went totally flat. Now, when I try to jump start it, it just keeps on turning over but never firing. And, as I turn the key, the alarm makes a little chirp noise. Is the alarm stopping me from starting????
Title: Re: Alarm reset.........?
Post by: Brikhead on 28 May 2011, 11:25:21
If the immobilizer is stopping your car from starting then the e.m.l. should flash.
Post by: Brikhead on 28 May 2011, 11:26:36
Have you misplaced the little chip from inside your key housing?
Post by: Brikhead on 28 May 2011, 11:33:15
http://www.google.co.uk/imgres?imgurl=http://i151.photobucket.com/albums/s127/rudemonkee/My%2520car/DSC05409.jpg&imgrefurl=http://www.astraownersclub.com/vb/showthread.php%3Ft%3D243624&usg=__hyk-873WyuMMIh7XJ_rE55heBnk=&h=600&w=800&sz=60&hl=en&start=0&zoom=1&tbnid=capbqrrijz4e3M:&tbnh=155&tbnw=211&ei=Hc_gTdOFFIOq8QOpueTvBg&prev=/search%3Fq%3Dvauxhall%2Bimmobilizer%2Bchip%26hl%3Den%26sa%3DX%26biw%3D1599%26bih%3D804%26tbm%3Disch%26prmd%3Divns&itbs=1&iact=hc&vpx=594&vpy=95&dur=2221&hovh=194&hovw=259&tx=155&ty=120&page=1&ndsp=28&ved=1t:429,r:2,s:0&biw=1599&bih=804
Post by: Rayviator on 28 May 2011, 12:17:17
Nope still there. It's a brand new key from Belgium
Post by: Rayviator on 28 May 2011, 12:17:52
Elm ?
Post by: fiend61 on 28 May 2011, 12:41:36
Elm ?
light which shows car with spanner through it  :y
Post by: Rayviator on 28 May 2011, 23:51:20
yes mate, its flashing like its never flashed before. does this have something to do with my new key?
Elm ?
Post by: Brikhead on 29 May 2011, 00:12:47
You need the little chip from your OLD key, it's coded to the Engine Control Unit in your car, thats why your Engine Management Light is flashing...
Post by: Rayviator on 29 May 2011, 11:58:36
Hmmmmm, I threw that away as I give the dealer my owners manual to them which had a card inside with the code on it
Post by: fiend61 on 29 May 2011, 16:43:24
oh dear looks like your bu**ered then
the key needs the transponder chip to talk to the immobiliser  :(
just read this and seems to me that the new transponder/chip hasnt been done/programmed right  :-/
you want this back  >:( and the dealer to do the chip correctly  >:(
