		Omega Help Area => Omega General Help => Topic started by: henri on 29 May 2011, 16:30:22
				Hi all
 Just a small problem trying to remove sensor at filter end but have'nt got a key to do the job anyone tell me the type of bolt it is,have got male torx keys but this looks like I need a female key? :-/
				I had the same peoblem a month ago. You need a female torx and good nerves
				Pic of Crank sensor/Eng No. location V6
 dont know about the nerves????????????? easy job to do  ;)
 if you cant get a torx socket either a 10mm or 8mm ordinary socket (cant remember which) tapped on will remove it  :y
				I hope it's easyer to do it on 2.5 , but i had to move away so many things just to get to it on my 2.0
 Easy to change on the v6 but follow the guide in the maintenance section re re-routing the cable
