Omega Help Area => Omega General Help => Topic started by: so comfortably numb on 10 June 2011, 14:11:21
Title: "DISPLAY SAFE" on CID
Post by: so comfortably numb on 10 June 2011, 14:11:21
I went to look at an Omega with an NCDC2013(?).  When I switched the ignition on the screen was like broken lines. I tapped it at the top of the dash and it came on properly only with the above msg displayed. I started the car and then the screen came to life with all the info but then went back to that message.  Could this possibly be poor connections?
Title: Re: "DISPLAY SAFE" on CID
Post by: Jimbob on 10 June 2011, 14:12:38
I think that means the components arent paired to each other.
Screen sounds knackered.
Post by: RobG on 10 June 2011, 14:16:33
IIRC if it flashes, 'display safe,' it can be coded with Tech2 using your car pass.
If it remains on 'display safe,' then you have a problem as it needs unpairing from the head unit it was originally fitted with.
But as Jimbob says, probably knacked
Post by: so comfortably numb on 10 June 2011, 14:23:03
Wide berth then!
