		Omega Help Area => Omega General Help => Topic started by: Field Marshal Dr. Opti on 14 June 2011, 16:54:33
				I'm half way through changing the rear pads on my MV6.(Lovely sunny day :y). The old pads have a separate chrome plate on the back (same size as the pad).The new pads do not come with this.
What is the function of this part? Should I use the old chrome plate when I fit the new pads?...
Any ideas please?
				They are anti squeal shims Opti, & yes refit them after cleaning them up & adding a thin smear of copperslip grease to both faces (don't get any on the braking surface!) :y
 Thanks Mr Phil. I thought that may be the case. The pads arrived from Ebay without any pins and clips. They said this is how they come . They did sent me a separate fixing kit the next day. :y
				I'm starting to get pissed now. First RRD Automotive didn't send me a fixing kit.  >:( >:( Now they've finally sent me one, the pins are too short and the clips are too small. I suppose all I can do now is refit the old pins and clips. >:( Not ideal. I haven't left any feedback for RRD Automotive yet ::) Remember this name.
(http://i970.photobucket.com/albums/ae183/janbowles/P1010003.jpg)
				thats the kit for the non vented disks, longer pins / anti rattle spring with the right ones. - springs dirt cheap at VX, pins came with my pads, as did the shims.
I didn't know that Mr Jimbob.
I've had to reuse the clips and pins after rubbing them down in order to rid them of the worst corrosion.
Quick fit wanted £89 to do the job. So I've saved £74.... :y :y :y
				someone may want those....bung em in the sales area  :y
				To be sure that they will fit I only use dealer parts. Everything is then supplied and the job is a straightforward one. Too many times have I had problems with aftermarket ones so now I just do not use them at all. I have 3 full sets of them that I put on then took back off after a few miles cos they were not up to scratch. Brakes are important so its not worth saving even a few quids really.
				RRD Automotive have contacted me and offered a full refund (£15.50) even though I have the new pads fitted to the car (with the old pins and clips). I'm guessing  it's their way of avoiding negative feedback.
Good news all the same.... :y :y :y.
I have a brand new set of pins and clips for non vented rear disc brakes if anyone needs them.... :y
				Win Win Result Opti!  :y :y :y
 I agree Stallion. A free rear brake service you could say. I actually enjoyed changing the pads myself too. Almost.  ::) :y :y
