Omega Help Area => Omega General Help => Topic started by: blackviper90210 on 19 June 2011, 08:33:53
Title: Lowering an Elite Estate
Post by: blackviper90210 on 19 June 2011, 08:33:53
Morning all,
Not being a mechanic, I have no idea.
What do you have to change to lower the car, is it the springs?
I don't want it mega low, just a fraction. I have to be careful as I tow a 'van too.
TIA  :y
Title: Re: Lowering an Elite Estate
Post by: albitz on 19 June 2011, 08:56:32
Yep, springs. I would think MV6 springs would be the way to go for lowering sensibly, but others may know better. :y
Post by: blackviper90210 on 19 June 2011, 09:05:11
Cheers Albs.
If thats the case rather than change the springs, could you just cut a fraction off the length of the current spring?
Or is that just downright stupid?  ::)
Post by: joff on 19 June 2011, 09:14:25
downright stupid
Don't do that, get the MV6 springs
Post by: blackviper90210 on 19 June 2011, 09:25:48
downright stupid
Fair enough, cheers Joff!!
Was just a thought, but totally binned now, lol  :y
Post by: Darth Loo-knee on 19 June 2011, 09:57:13
Morning all,
TIA  :y
I would ask what are you wanting to do with the car?
If you carry alot of weight in the boot then speed humps will be a problem even a steep drive. If your towing a caravan you may find the jockey wheel bottoming out too.
The plus side though when empty it corners with no wallowing.
Post by: feeutfo on 19 June 2011, 10:29:57
As you have an Elite the self leveling can work in your favor.
Fit what ever springs/suspension you want, but mv6 lowered sports chassis sound ideal for you giving 15mill drop, and retain self leveling rear shocks. Then tweak the level sensor arm if needed to give the hight you want at the back, although ime it seems to calibrate itself to a point.  :-/
Only trouble with this is self leveling shocks aren't the best when it comes to damping quality, but then if towing I wouldn't be without them.
Post by: blackviper90210 on 19 June 2011, 12:30:38
I don't usually carry anything majorly heavy, couple of times been to the skip and it's been a bit low, but thats once in a blue moon and filled the car right up!
I just fancy the look of the mig, just a fraction lower.
Just another wish on the long list of "I wants", lol.  ::)
Is swapping the springs over with mv6 difficult and are they expensive to buy?
Post by: feeutfo on 19 June 2011, 12:36:06
Sound like self leveling has failed then?
Sadly mv6 lsc springs are only available from vx, which with spring means they ain't cheap. But they are on tc. Pm andyc for a price.
There is a guide for spring replacement.
Post by: feeutfo on 19 June 2011, 12:38:46
Also be aware this sort of work will bugger any settings for camber and toe etc.
So fit first along with any other failed or ify parts, then setup, before fitting new tyres if that's on your list as well.
Post by: blackviper90210 on 19 June 2011, 12:39:43
Cheers Chris, will check the guide in a sec!  :y
Post by: jonnycool on 19 June 2011, 22:30:29
As said, maybe your self-levelling isn't working properly - I had about 300 kilos of flour in my car a while back and the back end didn't drop much at all
Post by: blackviper90210 on 20 June 2011, 06:26:09
If I remember rightly there was a post not so long back about checking self levelling, whether it's working or not.
I think I'll double check that first, cheers guys!  ;)
Post by: o-meg-a on 20 June 2011, 13:31:52
As you know
I fitted 35mm lowering springs on mine a while back and it has dropped it nicely.
But as previously mentioned, When i'm loaded up with gear, I have issues with speed bumps and steep inclines etc. The only bit that catches mind is the back of the CAT, and even that just scrapes.
The other bit that catches is the Bottom of my Witter Towbar, its a bit 3-4 inch deep plate so not surprised that catches really.
Other than that, i love it.
Looks mean too.
Tbh, i would say you wouldn't notice the LOOKS of a 15mm lower chassis much.... but you may FEEL it.
From the post though it sounds as though you'd like to be able to see it.
In which case i would say 35mm like mine might suit more.
It's not massively hard to do, but as also said before, any work you do will screw with your settings, and toe will be adjusted because of the lowering. This is not something you can set yourself along with the camber etc.
good luck tho, i can describe what you need to do in more detail in a PM if you need.
Post by: blackviper90210 on 20 June 2011, 16:24:13
As you know
Looks mean too.
Hi buddy,
Grounding out is my biggest worry whilst towing, which is why I only wanted it dropped slightly...
Its on a long list of wants at the moment, but with the cam covers, belt and service in need of doing first, its a bit lower down.
Was initially wondering if it's just springs that change and if the current ones could be "cut", but that is a BIG no no, lol.
Hows things with your mig? All going well?
Post by: Tony H on 20 June 2011, 18:24:47
Would the front springs need changing aswell? :-/
Post by: o-meg-a on 20 June 2011, 19:08:56
yeah, i think you're self levelers (if they're working) should stop any grounding out.
As for my mig, its ok. Just seen how bad my geometry is out tho after my lowering etc.
Front tyres have completely been chewed through. Was trying to at least make it till next couple of weeks cos then i'm heading over in the general direction of WIM anyway, Gonna have to put old wheels back on for a little while i think, and chew through the fronts on them too.
Backs are fine, no uneven wear at all.
Other than that, she's been a beauty.
Post by: blackviper90210 on 20 June 2011, 19:58:08
Yours did look good I must admit!!
