		Omega Help Area => Omega General Help => Topic started by: bruiser5050 on 20 June 2011, 22:57:12
				does anyone know how to definately diagnose a faulty Lambda without buying the new one first , Car running rich and reluctant to hold cruising speed so pretty certain its this ,
any help appreciated
Mat
				checked for codes i take it? by Pedal trick or code reader?
More than that, one of the tech2 gUys on here will no douBt.
Mat
WooWah test might help, try holding the revs at a steady 2k, if the revs rise and fall (hence the woowah) then it`s a sign the the lambda is goosed. Not definitive but it can point you in the right direction, also fuel economy might be slightly worse than normal.
