Omega Help Area => Omega General Help => Topic started by: Martin_1962 on 26 June 2011, 16:06:58
I had a suspected oil leak from the oil pressure sensor so I changed it today.
On a drive today at idle the oil warning light came on.
Why would this happen with the new switch?
Thanks Martin
Engine temperature was 93 or so
Any ideas anyone?
Do I need to drop the sump?
Is the old one faulty or the new one too sensitive?
Any MDTMs around?
well....youve changed the switch....
Possibility 1 - You have 2 Faulty switches.
Possibility 2 - You have an oil pressure issue.
Personally, I would be dropping the sump and cleaning the pickup pipe as that is a known problem.
Also gets you nice clean oil in, ready for monitoring.
I would hook up a manual gauge and see how much oil pressure you really have. Probably a faulty switch, as that's what you have changed, but you can't be too careful.
Been OK today ::) ::)
Will be dropping sump sometime anyway I have decided.
