Omega Help Area => Omega General Help => Topic started by: sticka_v8_init on 03 July 2011, 12:03:51
Title: Won't rev past 3,000 rpm when warm
Post by: sticka_v8_init on 03 July 2011, 12:03:51
Hiya, hope you fellas can help.
Taken the car out for its first run since buying it and noticed that when the car is warm it appears to hit the equivalent of the rev limiter at about 3,200 rpm - feels/sounds the same as rev limiter. Didn't do it when warming up, but felt that it wasn't revving freely up to 5,000 rpm compared to any other V6 Ive ever owned (Vauxhalls, Fords, Jeeps etc). In addition, the "gearbox/transmission" orange dash light comes on at the restricted revs (its a manual). Gets back home and it does the same 3,200rpm limit when stationary but with no gearbox/transmission light.
Any help with this is much appreciated.
Title: Re: Won't rev past 3,000 rpm when warm
Post by: MutantCav on 03 July 2011, 13:09:15
The restrictive revs is the car going into safe mode to protect itself as it recognises a fault that could damage the engine...
Post by: Andy H on 03 July 2011, 13:51:04
Read this guide Paperclip Test and Pedal Trick (http://www.omegaowners.com/forum/YaBB.pl?num=1189022687) to learn how to read the fault codes without using a code reader.
Come back and tell us what the fault codes are for advice on how to fix them  :y
Post by: Andy B on 03 July 2011, 14:51:47
exactly which warning light are you getting?
Post by: sticka_v8_init on 03 July 2011, 15:52:39
Sorry fella, got my interpretation of lights mixed up (no owners manual). Its the EML light :-[
Its a 2.5V6 so i don't think i can do the spanner light test.
Done the paperclip test with just the ignition on and again with the engine running. Both times i got a code of 19 and no other codes. Any help much appreciated.
Cheers
Post by: Andy B on 03 July 2011, 15:55:08
Cheers
Code 19 is a failing/failed crank shaft sensor. You really should consider replacing ASAP with a genuine Vauxhall sensor before the car lets you down completely.  ;) ;) ;)
Post by: sticka_v8_init on 03 July 2011, 16:03:07
Cheers
Cheers for that fella, would this be the sensor shown in the link below that sits just to the right of the intake plenum behind the right hand cam
http://www.ebay.co.uk/itm/VAUXHALL-CRANKSHAFT-CRANK-SENSOR-9174621-/200239034159...
Cheers
Post by: Andy B on 03 July 2011, 16:06:31
Cheers
Cheers
Your link isn't working, but it's next to the oil filter, the plug/socket is at the back of the engine towards the passenger side at the top.  :y
Post by: sticka_v8_init on 03 July 2011, 16:09:31
Cheers
Cheers
Many thanks for your help fella, much appreciated. Will pop down and pick one up tomorrow.
Thanks again  :y :y :y
Post by: Andy B on 03 July 2011, 16:14:34
... Will pop down and pick one up tomorrow.
They're on Trade Club if you have a card  :y
Post by: sticka_v8_init on 03 July 2011, 17:00:28
Yup! Got an Autobahn Stormers TC so hpefullt not too expensive. Had a look underneath and found the sensor in a nice easy place (just where you said). Looks a bit of a b*tch to get to topside, so might tie some wire to the end of the old one to act as a draw wire for the new.
Cheers again fella  :y
Post by: blackviper90210 on 03 July 2011, 18:42:40
There was a post just a day or so ago about this (can't find it though)  >:(
The wiring going to the back of the engine is set up in a way that it'll almost be impossible to get it out, let alone follow the original path with the new one!
The suggestion was to route it via the inner wing heading up then along the back to the block. Obviously avoiding sharp edges and hot pipes etc  :y
HTH
Post by: Broomies Mate on 03 July 2011, 18:49:41
Yep, Viper is right.
Better to re-route it, as it's original path encounters a lot of heat (hence premature failure).
Post by: sticka_v8_init on 03 July 2011, 18:58:32
Many thanks for the heads up on the routing fellas :y
Will take the advice and re-route as suggested. I take it that the new sensor cable will need extending, so will solder suitable heat spec cable and heat shrink it.
Cheers again :y
Post by: blackviper90210 on 03 July 2011, 19:12:37
iirc, there was no mention of needing to extend the wiring. I believe it'll be a case of using the available wiring to the best you can, again avoiding hot/sharp points!
Post by: MutantCav on 03 July 2011, 19:28:16
As blackviper says, no need to extend, just reroute using what you have :y And you can simply cut the ends off the old sensor and leave the wire in situ if you like...its easier as the old routing is tightly held between the gearbox (or oil cooler) pipework!
Post by: sticka_v8_init on 03 July 2011, 19:34:12
Cheers for the advice, sounds even better if i don't have to extend. Hopefully she will fly after this, let you all know.
Cheers again for all the help fellas, appreciated :y :y
