Omega Help Area => Omega General Help => Topic started by: 2woody on 23 July 2011, 22:40:15
Title: engine swaps
Post by: 2woody on 23 July 2011, 22:40:15
Just to get this right....
I've got a 52-plate 2.6 MV6 manual and an 03-plate 3.2 MV6 manual. Both facelift cars with the smaller-profile engine ECU.
if I wanted to put the 3.2 engine in the 2.6 car, I need to change the ECU and the immobiliser box hanging from the bottom of the ignition key housing, and then change the chips over in the keys.
is that it ? - will it run afterwards without Tech-2 intervention for example ?
Title: Re: engine swaps
Post by: albitz on 23 July 2011, 22:44:14
Possibly alarm ecu as well, but afaik, thats about it.
Post by: serek on 23 July 2011, 22:47:52
just swap engine and box dont need do any work on electrics. all will work fine :y
Post by: 2woody on 23 July 2011, 22:53:49
thought CU was different on facelift cars - the part munbers certainly are
Post by: serek on 23 July 2011, 23:05:27
yes they are, but both cars are FL and run on same type ECU, so if you can use engine loom from 3.2 on 2.6 just unplug 2 socket next battery and job done
Post by: Kevin Wood on 24 July 2011, 01:32:32
Not sure there's any difference between the maps anyway so I would try just swapping the donk at first, and see how it runs.
Otherwise, engine ECU, immobiliser by the ignition barrel and transponder chips.
Post by: Darth Loo-knee on 24 July 2011, 08:32:07
I would go with Serek here. I removed a 2.6 engine & gearbox as the engine had siezed. I fitted the gearbox to an excellent 3.0 engine then fitted it into my car. So a 3.0 engine using all the original 2.6 ECU etc. It goes a treat, had no fault codes up thats so ever.  :y
Post by: TheBoy on 24 July 2011, 12:05:51
I have a feeling it has a different configuration on it, but it probably should run fine.
If ever you bring it down south, I'm sure either Kevin Wood or I could ensure it has all the right configs on :y
If you do have to swap, its Motronic ECU, Immobiliser ECU and the transponders in the keys.
Post by: cem_devecioglu on 24 July 2011, 13:12:14
interesting  :y
fuel maps must a bit different at high end but if engine learns and changes ,there wont be any performance losses imo..
Post by: 2woody on 25 July 2011, 00:21:03
I might have a go without changing the ECU and see what happens. we have a local rolling road, so I'll get a feel for how far off the fuelling is afterwards - I expect quite a bit
Post by: 05omegav6 on 25 July 2011, 00:35:43
FWIW
Have swapped the manual ecu with an auto one on my 3.2, with no apparant side effects. :y
Also, 2.6 and 3.2 air intake systems are identical.
Same manifolds, same inlet bridge, same injectors, same throttle bodies. currently running the 3.2 with a 2.6 throttle body and inlet assembly with no issues. :y
(That is there are issues, but they are either from a weak spark on pot 6, or valve issues, also on pot 6. But that's a different thread altogether... ::)).
HTH
Post by: TheBoy on 25 July 2011, 08:52:50
Might need a few miles to 'learn'
Post by: Kevin Wood on 25 July 2011, 10:41:23
interesting  :y
Not necessarily. Fuelling is based on measured air mass, obviously with some calibration specific to the engine, but fundamentally, if you measure more air, you inject more fuel.
IIRC Robsey did a 2.6 to 3.2 conversion and ran it, initially, at least, with the 2.6 config. IIRC it was OK but, as said, it's not an issue to reconfigure or swap the ECUs if required.
Post by: cem_devecioglu on 25 July 2011, 11:50:25
interesting  :y
Kevin, if we are talking about 3.2 engine,  2.6 ECU will meet high masses of air entering the system that it will never see with a 2.6.. And I dont think the technicians preparing the 2.6 ECU map think that , " hmm. someone may connect it to a 3.2 donk , let me prepare for more " ;D :y
but apart from this a, lazy clever technician may prepare a very wide fuel map which can handle all volumes and use this single map for all, is another possibillity imo .. :-/
Post by: aaronjb on 26 July 2011, 04:51:37
Worst case scenario you might fall off the top of the open loop fuel maps, but the closed loop learned fuel trims will almost certainly bring it back to 'roughly' right..
For example - the MR2 (and I think this is common to all OBD-II ECUs) will allow up to 40% additional or subtracted fuel before it lights the CEL with an 'adjustment out of range' error.. that's enough extra fuel for quite a bit of extra capacity before it runs out of room to adjust itself.
Post by: 2woody on 26 July 2011, 10:03:04
40% ! that's ahuge margin. The last one I was involved in for a manufacturer had 4% and even then we thought that was too much
Post by: Kevin Wood on 26 July 2011, 10:22:38
The Omega seems to allow about 20% fuel trim before it gets upset and lights the EML. But that's not what we're talking about here. Fuel trim is a correction of the fuelling against what is calculated for the current mass air flow, under light to medium engine load.
Put a bigger engine in and the mass air flow at wide open throttle increases; hence the calculated fuel requirement increases, and it'll be roughly correct for the engine so no need to increase fuel trim (it'll actually be running open-loop by then anyway, so the ECU won't know if the fuelling is right). Granted, at some level the ECU will regard the MAF reading as not plausible but the question is where that threshold is set.
Post by: cem_devecioglu on 26 July 2011, 10:55:29
at least we know with a bigger engine and full throttle we are in the twilight zone ;D
