		Omega Help Area => Omega General Help => Topic started by: hamody on 28 July 2011, 12:12:01
				HI ALL , I HAVE OPEL OMEGA 2.5 MV6 MY AIRCON DISCONNECTED WHEN THE ENGINE TEMPERATURE REACHED TO 90 WHAT CAN I  DO FOR THIS PROBLEM.
				First thing to do is get the pressures checked.
 Does the system work once its cooled down.
 Has it been re-filled recently?
 I have seen one system that was overfilled and this shutdown at high temps and started again after the fans had been running for a while (and the system cooled a bit), this was tripping the over pressure switch.
				yes i  re-filled recently thank you
				In which case you may well have to much gas in it, was it a fully evacuated system which has had a weight of gas added?
				YES THE SYSTEM WORK AGAIN WHEN THE COOLED DOWN, I THINK THE GAS PRESSURES 45 I WELL CHECKED.
