Omega Help Area => Omega General Help => Topic started by: valliant72 on 05 August 2011, 18:29:00
Hi, got and error code 14 coolant temp sensor voltage low. Is this the sensor for the dash gauge or the Ecu.
Thanks
ECU. :)
Worth checking the wiring as much as possible before swapping out the sensor, but access to the wiring will probably be hideous. :(
