Omega Help Area => Omega General Help => Topic started by: Figureman52 on 07 August 2011, 21:48:27
Title: Changing Exhaust
Post by: Figureman52 on 07 August 2011, 21:48:27
Planning to change both centre boxes and back box tomorrow. are there any special tips I should know about when doing it? I have heard that the front bolts can easily shear off.
Title: Re: Changing Exhaust
Post by: Andy B on 07 August 2011, 21:54:18
... I have heard that the front bolts can easily shear off.
For reasons known only to someone at GM the holes in the downpipes are threaded instead of clearance, so the bolts rust solid into them. You can try a proper penetrating oil ie Plusgas a few days before you do the job, but you'll either be drilling out the bolts & re-tapping the holes M8 (tapping size 6.8mm or 17/64") or drilling clearance holes in both.  :y :y
Post by: albitz on 07 August 2011, 22:11:01
Wot Andy said. Its a bit of a pig of a job with the frontpipes/cats still on the car.The higher you can (safely) raise the car the better. :y
Post by: tigers_gonads on 07 August 2011, 22:25:30
With all the bolts, give them a good coat of plusgas the day before  :y
Also hang your new system on its hangers and push together.
Refit the bolts BUT leave them a little loose until you had got everything in the right place without bits touching THEN nip all the bits and pieces up  :y
The amount of times I have changed one piece on my exhaust and nipped it all up only to find something has moved a little and it starts banging and rattleing  ;)
Post by: tidla on 07 August 2011, 23:11:39
if you have access to oxy acet heat then your sorted.. or get a garage to do that part.(heat nuts, bang on a socket that fits and remove)
save your self a load of hassle.
Post by: Figureman52 on 08 August 2011, 08:48:44
Thanks for the info, I'll give it a go and see what happens. :y
Post by: Figureman52 on 08 August 2011, 20:02:53
Job done. :) Gave the bolts a good spray with penetrating oil and got 'em all out. Thanks again for your advice. :y
