Omega Help Area => Omega General Help => Topic started by: albitz on 08 August 2011, 14:39:03
Title: Door check strap ?
Post by: albitz on 08 August 2011, 14:39:03
Is this the infamous broken check strap thing that I can remember reading about on the forum.Looks like the metal has torn and the part that the strap attaches to has been bent back inside the door ?
If so, is it feasible to repair ?
(http://i1238.photobucket.com/albums/ff500/Albs59/DSCF1123.jpg)
(http://i1238.photobucket.com/albums/ff500/Albs59/DSCF1121.jpg)
Title: Re: Door check strap ?
Post by: Andy B on 08 August 2011, 14:54:50
This is as you say. If you use a reinforcing plate either side of the door skin ASAP you'll have an almost as good as new door. The metal had come away completely on my door, and the repair has lasted for a good number of years. The plates are easily made if you have access to material, but are only pennies to buy from the dealers.  :y
Post by: albitz on 08 August 2011, 14:57:33
Thanks Andy, will look into fixing it then.  :y
Post by: Olympia5776 on 08 August 2011, 17:36:42
Here's the part nos. too.
(http://i162.photobucket.com/albums/t261/olympia5776/FinepixuptoFeb20101127.jpg)
Post by: albitz on 08 August 2011, 17:39:10
Excellent, thanks. :y
Post by: albitz on 09 August 2011, 08:44:01
Any tips for bending the metal back to where it should be before trying to fit the reinforcing plates ? Looks like its going to be awkward. Very little access. :-/
Post by: albitz on 09 August 2011, 13:48:37
Went to local VX dealer and the parts guy got a bloke from the body shop to come and speak to me.
In his opinion, the repair kit (as shown above) wouldnt be much use. It really needs the spot welds drilling out and that part of the door replaced with a bigger repair plate, which used to be available, but may not be available now
He thinks the smaler plates are ok for doors on smaller models but not  for an Omega door.
They didnt have any in stock anyway, so Im still stuck. :(
Post by: Jimbob on 09 August 2011, 13:51:20
ignore him, many of us have totally knackered doors held together with these, they are fine, and dare I say it....stronger than original.
order from andyc.
use a screwdriver / chisell and gently tap flatish, then use the plates
one on Ljays car was damn near torn out - strong as you like now after fixing at Newent last year  :y
presume youve read
http://www.omegaowners.com/forum/YaBB.pl?num=1152902108
iirc speaker removal give some handy extra access to the back of it
Post by: RobG on 09 August 2011, 13:52:00
Get a door of twiggy`s Elite. Least it won`t be pock marked with rust spots ::)
Post by: twiglet on 09 August 2011, 14:02:50
I have offered him one on a free exchange Rob, but you know what a stubborn bugger he can be!  ::) :P :-X
Post by: albitz on 09 August 2011, 14:47:04
My car is 147 and yours is 157.Im concerned that the difference in shade will stand out like a sore thumb. :-/
Offer is much appreciated though Mr. Twig. :y
Post by: RobG on 09 August 2011, 15:42:19
Your concerns are unwarranted. See my reply in other post :P
Post by: albitz on 09 August 2011, 15:43:41
Just have, thanks Rob. :y
Post by: Andy B on 09 August 2011, 18:18:20
the body shop bloke was half right in what he said. If your door had broken when the car was only a few years old with xxx miles (60k  :-/) then Vauxhall would have done the repair that he suggested. It involved removing the section shown in photo & plug welding the new panel in. I bought panel (a few quid), then realised exactly what the repair involved so didn't bother. The metal on my door had ripped out completely but has been OK with a sandwich using a repair kit for past number of years.  :y
(http://i84.photobucket.com/albums/k17/Tiff4327/General/Checkstrap.jpg)
Post by: albitz on 09 August 2011, 18:21:35
That makes sense Andy. Thanks for that, I was a tad confused - doesnt take much to do that though. ;D
Post by: al brown on 09 August 2011, 18:25:44
If it helps, when I repaired mine I open the door as far as it would go. Slowly but firm enough to bend the fixing back to somewhere near to where it used to be. Then disconnected the strap while the door was all the way open. Have done both of mine, one I welded back up and the other I made some plates up, was before I joined OOF and never thought to try vx. I agree about removing the speaker, gives you a lot more room and you can easily get to the back of the door to finish flattening the bent part before fitting the repair.plates
So
Post by: albitz on 09 August 2011, 18:28:48
Useful info, thanks Al. :y
