Omega Help Area => Omega General Help => Topic started by: andrew38 on 10 August 2011, 18:05:20
I have a new bumper to fit which has in the pressure washers, I was just going to leave them on not plumbed in but the donnor car has all of the system in place still. I have a CD model 2002 is it straight forward to get the washers operating and if so what bits would I need off of the old car, i.e pump and wiring etc. Many thanks I could not find an FAQ.
Washer reservoir with the hosing, use pumps in replacement reservoir, black relay from the front of box near battery. Job done
(http://i190.photobucket.com/albums/z257/belisensis/Headlampwasherrelay.jpg)
Thanks Rob, any wiring I need it must plug into the wiring somewhere from the fuse box?
Nope, all the wiring is on your car. The connector for the headlamp wash pump will be tied to your existing wiring near the sreen wash pump :y
Thanks Rob thats good news, nearly as easy as retro fitting cruise control.
You will need the green fuse next to the relay as well :y
Should be there already
Mine wasn't when I did my CD - was a MFL though
My CD F/L had one :P ;D
Thanks for the replys covered my bases and asked for the green fuse as well:-)
