Omega Help Area => Omega General Help => Topic started by: Daz1111 on 17 August 2011, 19:27:06
Title: Diesel Splutter
Post by: Daz1111 on 17 August 2011, 19:27:06
Hi all, I've got a small problem with my 2.2DTi Est (52 plate).
It drives great just about the whole time except for when I am cruising at about 45 - 55 mph. If I am light on the accelerator I get a splutter when I lift off.
It doesn't happen if I'm heavy footed or on Cruise control!
Any diesel experts who can tell me where to start looking  :-/
Thanks
Title: Re: Diesel Splutter
Post by: freecall666 on 17 August 2011, 23:19:17
dose it do it standing, rev a little till you at the same revs as if you were doing 45-50mph see if it dose it then.. if it dose check the throtle sensor.. may need a clean.
Post by: VXL V6 on 19 August 2011, 17:45:55
I'm guessing you get this splutter below 2.5K revs (ie. before the turbo cuts in)?
Usually happens when driving on a light throttle and not when you accelerate with a heavy foot. I have these symptoms on mine and initially thought the fuel pump was failing. I replaced the EGR valve (as also had a P0400 code very intermittently) and this improved the splutter issue greatly, however it did not solve it completely. I think my next port of call will be to remove and clean the inlet (the part the EGR bolts to) and also swap the solonoid vacuum valve connected to the EGR vac line on the bracket by the power steering bottle.
Post by: hoofing it on 19 August 2011, 19:19:50
Somtimes it helps giving it a Italian tune up as diesels carbon up if not driven hard now and again. :y
Post by: VXL V6 on 19 August 2011, 19:31:15
Yeh, tried that... Well at least once a day I perform this essential surgery  ::) ;D
Post by: Daz1111 on 19 August 2011, 19:32:30
Thanks for the responses all.  :)
In answer - no, it doesn't do it when the car is stationary.
Yes, it is when the revs are below 2.5k. I'll try cleaning the bits you suggest and see what happens. The problem isn't bad so I'll do the easy stuff first! :y
And yes it did need a bit of clearing out - went to overtake someone on a quiet Norfolk road, stuck it in 3rd and floored it! I don't know where the other car went as when I looked in the mirror he had disappeared in the cloud of smoke!! ::)
Post by: VXL V6 on 19 August 2011, 19:45:03
Turbo is spinning up nicely then!  ;D
