Omega Help Area => Omega General Help => Topic started by: SR-71 Blackbird on 20 August 2011, 21:42:31
Title: TD Oil filter housing cap broken
Post by: SR-71 Blackbird on 20 August 2011, 21:42:31
Hi guys,
My plastic cap on the oil filter housing is broken, some of the plastic bits that forms the sides of the hexagon are snapped, why the heck did they make them out of plastic?!?!?!? What were they thinking? Does anyone know if the BMW ones are metal and if so where would I get one or does anyone know the part number of it? Thanks
Title: Re: TD Oil filter housing cap broken
Post by: Andy B on 20 August 2011, 21:53:15
.... why the heck did they make them out of plastic?!?!?!? What were they thinking?  ...
Manufacturers can't win!  ;D ;D When they fitted ally oil housings for the V6, peoplecomplain they can't get it off! ::) ;D ;D ;D
Post by: SR-71 Blackbird on 20 August 2011, 21:57:11
I can imagine, over time mine have started to weaken and today as I was tightening it up it crack a bit and I think it will be a problem to get off and I will need a new one anyway. Can anyone help? I take it that its not a standard part but specific to the M51 engine so Omegas, BMW and Range rovers?
Post by: Andy B on 20 August 2011, 22:01:00
.... as I was tightening it up it crack a bit and  ....
How tight did you tighten it?  :o Can't say for the diseasal Omega but her Smart has a plastic oil filter cap & that's tightened to 25Nm  :y :y
Post by: SR-71 Blackbird on 20 August 2011, 22:03:08
Not exessively the plastic bits were weakened anyway and I knew I would have to replace it at some point and now is the time  ::)
Post by: TheBoy on 20 August 2011, 22:03:15
GM didn't chose the filter cap, BMW did.
Early ones (Vx, Landrover, BMW) had metal caps, later ones (again for all marques) had plastic ones.  They are not interchangable (without changing the entire housing and pump)
Post by: TheBoy on 20 August 2011, 22:04:32
Should add, whilst it does occasionally happen, the plastic caps are not particularly problematic (if retarded monkeys at dealers don't act like pricks)
Post by: Seth on 20 August 2011, 22:09:53
BMW part number is: 11422246171
The torque value for tightening these is quite low, and shown on the filter-cap.
I always use a 3/8" drive 'low profile' socket for this job.
 :y :y :y :y :y
Post by: SR-71 Blackbird on 20 August 2011, 22:20:19
Thanks TheBoy and Seth,
Ok great so would the BMW dealer be the best bet then? Anyone know roughly how much they might be? Its a bit tricky finding it on the internet at the moment.
Post by: Seth on 20 August 2011, 23:59:43
In my experience, yes.
It would be worth trying your local Land Rover people too, as some parts for this engine have proven to be cheaper from them.
HTH ;)
