Omega Help Area => Omega General Help => Topic started by: Figureman52 on 24 August 2011, 12:50:26
Need to take the rear door card off to find out why the electric window doesn't work and the puddle light only comes on at certain door positions.
Presumably it must be a bit of faulty wiring.
Are there any special things I need to know, hidden screws for instance?
Thanks
One behind ashtray, one under rubber bung in "finger pull"
Check for damaged wiring in the rubber umbilical that carries the loom from the car body to the door, you may not need to remove the door card...
