Omega Help Area => Omega General Help => Topic started by: tidla on 06 September 2011, 20:43:27
emptying the reservoir once a week now so time to bite the bullet this weekend.
how much is the housing and the other bit that breaks??
Got that here mate, used but good condition, you`d just have to get the stat
Your sure its the Thermostat?
Not sure if I would fit a secondhand one being honest though.... :-?
trail of red from the housing, behind the belts to the top of the sump..
(hbv done)
.... behind the belts to the top of the sump..
(hbv done)
could that not be your water pump?
starts higher up, cam seals need doing as well..
(pump done)
(pump done)
Ah! ;)
Due to the dismantling involved to get to the 'stat I agree with Daz ie fit a new one. :y :y
Could be a leaking oil cooler ::) ::)
I would get it all stripped to the thermostat but not remove it. Block off the water pipes, then put the water system under pressure you will be sure then where your leak is :y
sounds like a plan, water pipes being the throttle heater pipes.
Yes mate :y either bolts in the end then clamp them, or a couple of pieces of flat clamping the ends works too. Pressurise up to about 10lb then watch out for the leak... :y
Thats what I would do anyway ;)
