Omega Help Area => Omega General Help => Topic started by: Anthony in Madrid on 11 September 2011, 11:39:17
Title: Wynns injection cleaner???
Post by: Anthony in Madrid on 11 September 2011, 11:39:17
Hi everyone
Has anyone used "Wynns Injection cleaner" and what were your results? Positive or negative?
Appreciate your input thanks
Anthony :y
Title: Re: Wynns injection cleaner???
Post by: Auto Addict on 11 September 2011, 12:11:34
I think most on here recommend Fuchs.
Post by: Anthony in Madrid on 11 September 2011, 12:13:37
I hope that's not a spelling mistake ;)
Post by: Jimbob on 11 September 2011, 12:13:48
Thats gearbox oil...
Forte Advanced formula gas treatment is the fav...
prob followed by STP injector cleaner,
then redex
Not heard much about the wynns one.
Post by: cem_devecioglu on 11 September 2011, 13:12:40
If I were you I would spend the money (yes a bit more) for flow test and sound cleaning instead.. (they also use a chemical cleaner at the same time)
Post by: Stallion on 11 September 2011, 14:28:36
iv used BG44k in the past and would recommend it, but it does weigh in a little dearer then redex etc..
Post by: Alex W on 11 September 2011, 15:21:39
I used Wynns and it did a good job cleaning out my breathers.
Post by: Anthony in Madrid on 11 September 2011, 15:25:45
Is cleaning the injectors yourself an easy job ?
Post by: dbug on 11 September 2011, 16:16:08
I use Wynns injector cleaner - usually once a year - and there is a noticeable improvement initially.
HTH
Post by: cem_devecioglu on 11 September 2011, 16:51:02
taking the injectors out fairly, but you will need an expensive equipment which only some garages have..
but no doubt its far effective than any bottle of cleaner , also you will have the chance of checking their spray pattern..
http://www.google.com.tr/imgres?q=injector+checking&um=1&hl=tr&sa=N&rlz=1R2SUNC_enTR388&tbm=isch&tbnid=iQtUm3v3OEOfJM:&imgrefurl=http://www.theboostlab.com/fuel-injector/cleaningprocess.html&docid=ANkvXr-xehLrJM&w=700&h=412&ei=dthsTrm2Esjm-gbmwODuBA&zoom=1&iact=hc&vpx=793&vpy=499&dur=94&hovh=172&hovw=293&tx=142&ty=119&page=7&tbnh=111&tbnw=188&start=164&ndsp=27&ved=1t:429,r:24,s:164&biw=1398&bih=791
http://www.google.com.tr/imgres?q=injector+checking&um=1&hl=tr&sa=N&rlz=1R2SUNC_enTR388&tbm=isch&tbnid=fvdCrBbQ_BLXmM:&imgrefurl=http://www.alfabb.com/bb/forums/alfa-romeo-parts-sale-wanted/158694-fuel-injector-cleaning-flow-checking.html&docid=vfymcLm0g-og0M&w=698&h=874&ei=dthsTrm2Esjm-gbmwODuBA&zoom=1&biw=1398&bih=791&iact=rc&dur=188&page=1&tbnh=151&tbnw=115&start=0&ndsp=27&ved=1t:429,r:25,s:0&tx=45&ty=59
Post by: Auto Addict on 11 September 2011, 17:41:25
then redex
Sorry, I meant Forte :-[
