Omega Help Area => Omega General Help => Topic started by: SteveT528 on 11 September 2011, 12:11:55
Title: 2003 2.2 dti no ecu light + buzzing relay
Post by: SteveT528 on 11 September 2011, 12:11:55
Hi all ive had enough of this omega, the 2.2 dti has really put me off any vauxhall diesel if im honest! ive changed everything to cure a lazy starting problem, last thing ive done is injector seals... now the car wont start at all i have no ecu light at all and the rev counter moves upto 1k and stays there. - i also get a buzzing relay under the bonnet which ive found out is the main engine relay on tis2000. ive tried a new relay with no luck. and checked every connector / earth with no luck.  Any idea?  :y anyone that finds the solution i will reward as im just about ready to scrap the car  ;D
Title: Re: 2003 2.2 dti no ecu light + buzzing relay
Post by: Sam Burton on 11 September 2011, 17:51:28
ill take it off your hands :) and ill come get it
Post by: SteveT528 on 11 September 2011, 17:54:59
pm sent  :y  its now running, for anyone having the same problem it was a bad earth to the ECU.
problem is its still getting air into the fuel so dont like starting.  >:(
