Omega Help Area => Omega General Help => Topic started by: Peter13 on 16 September 2011, 07:54:42
Title: V6 O2 sensor(s), what could happen?
Post by: Peter13 on 16 September 2011, 07:54:42
Hi Guys!
Last year I was getting the MIL blinking sometimes, then more and more frequently. When it came always during moderate accelerations on highway, I replaced the lambda sensors. Replacement came from ebay called "Vauxhall Frontera Omega LAMBDA OXYGEN SENSOR - 90509274"
It was not original Bosch 90509274.
Then the fault kept coming. Okay, I had had a replacement ECU, I put it in. Same issue. There were problems with my head gasket, I replaced it a month ago and did a full head renewal at shop.
Current status:
Engine is running smooth and fine, but I have the MIL permanently on, however the car has just passed the emission test with outstanding results. (its results also fit the euro4 standard!)
Paperclip test shows 13 and 89, which should mean both my lambda sensors are open circuit. I have checked yesterday, they are connected and fitted well.
(before the head removal sensor 2 went to open circuit sometimes during acceleration, and I am afraid I may have broken the cable for sensor 1 during the head job, but this is too much I think)
Finally the question: can I do anything else to diagnose this issue than buying new sensors again?
Title: Re: V6 O2 sensor(s), what could happen?
Post by: cem_devecioglu on 16 September 2011, 11:53:14
you can measure the voltages at connections and impedance of lambda sensors and if possible find someone with tech 2 and monitor them..
http://www.picoauto.com/applications/lambda-sensor.html
ps: using ohmmeter on some lambda sensors may create problem so please read the link ..
Post by: Peter13 on 26 September 2011, 11:42:51
I have checked the voltages using an "My Naff Code Reader".
One sensor is quite okay, close to 450mV when idling.
The other shows 20-50mV during idle, and can go up to 900+mV when reving up. This is weird.
Another thing that the fault shows signs of disappearing:
After the maintenance work MIL started to lit permanently. On the way to home at the weekend it went out sometimes, on the way back today MIL came to on only sometimes. ????
I am about to record data of a whole drive.
Post by: Kevin Wood on 26 September 2011, 11:45:17
Both lambda sensors should be cycling between <200mV and >800mV all the time at idle and under light load if they are working properly.  :y
Post by: Peter13 on 10 October 2011, 14:21:10
Latest new on this:
I have replaced one of the sensors (left side, passenger's side for you - driver's here), which seemed more often to go open loop.
A few miles after, on the way from the shop to the office the MIL light went off, but if I looked to the laptop on the seat near I saw the read signal value is still low and stable when I was stopped at trafficlights. It was okay when the car was moving.
I will upload the before and after logs from my "My Naff Code Reader" in the evening.
Post by: robmac on 10 October 2011, 15:19:37
possible air leak maybe in exhaust/manifold on that side???
Post by: Peter13 on 10 October 2011, 20:10:23
I am starting to assume the same..., but no strange/thicking noise, no visible sign of a leak on the exhaust manifold.
How could I get evidence of an exhaust leaking?
Post by: cem_devecioglu on 10 October 2011, 21:07:45
you will smell unburnt fuel from the car (car revved a bit and you are outside) as the mixture gets richer.. and the consumption a tad higher than  usual..
Post by: Peter13 on 10 October 2011, 21:21:33
Nothing like this for fortune.
I have downloaded now the logs of today. One on the way to the shop, second from the office to home.
Findings: originally I have very often had both my oxygen sensors in open loop together. (from line #2700 in before xls)
After replacing the left (passenger's side in UK) sensor, I see sometimes only the Loop1 to go open. This is strange cos I believed sensor 1 is on the left and sensor two belongs to the right. However this is contradictional to the fact, that the pistone #1 is on the rdriver's side(right). (see from line #1160 in the after xls)
I do still have the low but closed loop state radings when idling.
Does this mean sensor replacement did the job and I should replace the other one as well?
http://landboyz.4step.hu/20111010_before_2.xls (http://landboyz.4step.hu/20111010_before_2.xls)
http://landboyz.4step.hu/20111010_after_left_o2_sensor_2.xls (http://landboyz.4step.hu/20111010_after_left_o2_sensor_2.xls)
Post by: Peter13 on 18 October 2011, 10:17:47
Hi All!
I think I am on the way to figure out this.
When I check the lambda signals in idle they show very lean mixture (<100mV). Then I tried to disconnect the MAF sensor and voila, both lambda voltage started to alternate between 150mV and 900mV!
Now I assume that will be a vacuum leak or my MAP sensor is gone. (no fault code yet for it. live data seems okay)
Another concern is the ignition timing. Is that normal that I see almost always the knock signal inactive in logs? And knock retard at ZERO?
You can check in the xls linked above.
What is the normal spark angle in idle?
Post by: Kevin Wood on 18 October 2011, 10:32:58
Hmm. MAP sensor problem perhaps?
That's exactly what you want to see. Knock signal should stay inactive. If not, it starts retarding the ignition to save the engine.
It varies widely at idle as it's used by the ECU to stabilise the idle speed. I'd say anywhere between a few degrees negative and about +12.
Post by: Kevin Wood on 18 October 2011, 10:42:32
Oh, and as you sit in the car, sensor 1 is on the right. On the same bank as cylinder 1. So, bank 2 has improved and bank 2 is the sensor you swapped, IIRC? Maybe it was just tired lambda sensors?
Disconnecting the MAF probably forces the system into closed loop, since there is no load input available, that's the best approximation the ECU can make, so the Lambdas will start toggling regardless of the amount of fuel trim required.
Post by: Peter13 on 18 October 2011, 12:09:42
According to my available documentation states the sensor 1 is on the left side, despite the piston1 is on the right. I don't think this is because I drive an opel.
This doesn't matter because it seems any of them can go to open loop and very lean before.
As far as I know the sensor voltage can be substituted only to 450mV by the ECU when it can not read the signal voltage or it is out of range. So I'm happy with my working sensors (now I have 4 of them :))
Post by: Kevin Wood on 18 October 2011, 12:49:04
I think the ECU is more intelligent when the MAF sensor fails. The car would no be remotely drivable with a basic substitution but in practice it's not too bad. :y
Post by: Peter13 on 18 October 2011, 13:44:30
I am going to replace the MAF today in the evening and will do air leak tests as well... Will report back tomorrow!
Post by: Peter13 on 18 October 2011, 21:29:12
MAF replaced, nothing happened. I have searched around the engine for leak with a carb cleaner spray, no success.
Then something happened on the way home, there was no MIL at all for 60km and the fuel economy increased incredibly.
I stopped the car 4km from my home to visit a friend. After 2 hours when leaving for home, everything started from the beginning ....
arrrgghhh!!!!
Post by: Peter13 on 02 November 2011, 09:00:50
Hi Guys,
as the afterword of this topic here comes the solution!
At the weekend I have jumped under the hood, still suspecting there must be somewhere an air-leak. Checked every vac hoses and followed all the breather pipes.
When I pulled one at the back of the plenum, it was coming so easy... and then:
(https://lh5.googleusercontent.com/-1lSsDPEjZzU/TrEGWonjexI/AAAAAAAABxk/Q_rnOeLyT2g/s1024/DSC00040.jpg)
