Omega Help Area => Omega General Help => Topic started by: bald stan on 18 September 2011, 15:03:05
Title: Water ingression
Post by: bald stan on 18 September 2011, 15:03:05
 Hi Guys having a lot of water leaking inside my car (omega 2.2 saloon) nearside only and mainly in the rear of the car,not leaking from the car Its only when it rains, door seals are ok but I cannt find a drain,any help please the car is begining to smell abit now :(
Title: Re: Water ingression
Post by: tunnie on 18 September 2011, 15:05:16
Assuming you mean the rear and not the front. Which is could be caused by a blocked pollen filter drain, by the heater matrix,
I had same problem, there was a hole in the floor of a car which I think used to hold a carpet bolt:
(http://dl.dropbox.com/u/803897/Omega/Misc/hole.jpg)
I sealed it with a load of araldite  :y
Post by: Agemo on 18 September 2011, 15:06:40
Usual culprit is the sunroof drains, this is where you say you don't have one. Next is the scuttle drain, behind the pollen filter.
Post by: bald stan on 18 September 2011, 15:12:34
ABSOLUTLY RIGHT I dont have a sun roof but I will check pollen filter thank you
Post by: tunnie on 18 September 2011, 15:18:30
Pollen filter drain, will cause the front passenger carpet to get wet & if left long enough or you park on a hill it may roll down.
Water in rear footwells, check underneath of car body  :y
Post by: robson on 25 September 2011, 19:55:29
water in my car was a leaking windscreen
Post by: fiend61 on 25 September 2011, 22:57:08
sorry for hijacking thread, but i get water in rear nearside footwell  >:( now someone mentioned sunroof drains ???? how do i check/cure this ????  i have looked under car but cant see any holes etc
tia
