Omega Help Area => Omega General Help => Topic started by: omegaman2 on 19 September 2011, 09:24:29
i have slight play in the 12 o clock 6 oclock position on offside front ,im thinking wheel bearing is on the way out if this is the case anyone know of good suppliers ex vx :question
If the play was in the wheel bearing you'd feel it at all positions of the wheel. ;)
More likely to be the wishbone balljoint or strut if it's at 12&6, IMHO.
Get an assistant to rock the wheel while you feel for play in each joint / bush by bridging your hand across it.
thanks for that advice :y
Also get somebody to stand on the brake pedal, if the play disappears then its wheelbrg, if the play is still there then it's not wheelbrg.
Alan
