Omega Help Area => Omega General Help => Topic started by: TheBoy on 08 September 2011, 11:03:08
Mine is leaking. I believe they unscrew? Anyone know how, and if special tool reqd?
TIA
Andy B is your man,I seem to recall that he has replaced one of his
Surely one for an ac specialist? Valve can't be expensive to add to a normal ac service...?
TIA
The valve on top unscrews like your tyre valves, the other at the front requires a 15mm socket & a 17mm(?) spanner to support the boss welded to the pipework.
(http://i84.photobucket.com/albums/k17/Tiff4327/Omega/S73F1430.jpg)
TIA
It is quite fragile where it is welded, but is easy to replace.
The pipework? Far easier to not have to replace it ;) ;)
Anyone know part no for front one? Can only find part no for top, presumably different, going by Andy B's comments?
By the top part, is that the one nearest the firewall and just back from the ICV? if so can someone post the part number for that as mine has gone and i'd like to replace.
If you haven't found it in past threads I'll post it later when I get home from work ............... andyc found it for me in the first place though. :y
http://www.omegaowners.com/forum/YaBB.pl?num=1288015288/all ..... any use? :-/
Found it!!!
http://www.omegaowners.com/forum/YaBB.pl?num=1309525980/all
(http://i84.photobucket.com/albums/k17/Tiff4327/scan0002.jpg)
This number needs saving in the maint section ;)
EPC doesn't recognise that number, though if andyc supplied it, I'll try it :y
Get a few if he does, mother T's estate needs one, and be useful having a spare :) :y
Found on EPC
5248177
EPC also lists 3041827 for 2.5 and 3.0, which matches PN for top valve
Found it!!!
Ordered :y
Found it!!!
Ordered :y
:y :y :y :y Make sure you support the boss that it screws into so you don't snap the whole lot off the ally pipe. :y :y
Valve is 15mm across the flats. ;)
Found it!!!
Ordered :y
Need to clean mine up so I can actually see what is part of pipe, and what is part of valve, then I should be able to get my head around it :y
Was it tight?
Got one here TB off the 2.6 elite i will bring it on Saturday. Saying that i must have the pressure checked on the estate as aircon has stoped working in the past few weeks, was OK when i went to Scotland in July. :-?
Found it!!!
Ordered :y
Was it tight?
Mine wasn't particularly tight, they don't need to be .............. but neither does an oil filter cap and we all know how tight they can be. :-X
Just use your socket over the top, IIRC the bit that it screws to is 17mm across, the valve is 15mm so it won't go any further. ;) ;)
No need, 2 on order from dealer :y
Found it!!!
Ordered :y
Was it tight?
Sounds like even an idiot can do it ;D
Did it come with the O-ring seal that I can see in your pic?
Found it!!!
Ordered :y
Was it tight?
I asked if they came complete with a seal, he didn't know so I ordered a separate seal .......... so obviously it came with one! :y :y
Is there anyone on here anymore that can do a re-gas as i would not like to get ripped off to much. i know simon used to do it but don't think he is around on here anymore. :-/ :-/
Halls Electrical in the Blagrove Industrial Estate do a good job for just under £40
http://www.hallsautoelectrical.co.uk/air-conditioning
Used them before Nige cost me £300 and each time they found another cash builder :-[ :-/
