Omega Help Area => Omega Electrical and Audio Help => Topic started by: tonycooper on 02 August 2007, 14:32:21
Title: coolent low
Post by: tonycooper on 02 August 2007, 14:32:21
got a message that keeps on coming on the dash coolent level low
there is plenty of water in header tank, no air in rad what else can it be?
Title: Re: coolent low
Post by: Jimbob on 02 August 2007, 14:42:17
Faulty sensor
These often go, esp if coolant runs down the tank and knackers it.
Few things to try,
open the cap and 'jab' at the float, make sure it is free,
you could disconnect and clean the inside of the tank.
These may or may not help, best bet may be to buy a new tank and fit that.
You could just unplug the sensor, but it is a nice early warning of things like HBV on its way out.
The one in the wife's is currently unplugged, its nearly due cambelt and water pump, so when i drain it for that, it can have a new tank as well.
Post by: tonycooper on 02 August 2007, 14:53:53
jabbed the float light has gone off thanks mate :y
Post by: Jimbob on 02 August 2007, 14:57:58
No worries, they can stick a bit.
now with my (now fixed) coolant leak, the float had a great workout, full up to full down daily!
Post by: TheBoy on 03 August 2007, 09:18:30
Worth cleaning out the tank then, I imagine you have some grimey scaly stuff, normally a result of previous more maintenence...
