Omega Help Area => Omega Electrical and Audio Help => Topic started by: RobG on 06 August 2007, 16:14:02
:-? What`s the procedure for removing the audio control switches from the steering wheel. When I press to increase volume it decreases and when I press to decrease volume nowt happens. I assume that the switch is knacked. Any advice would be appreciated. :)
Disconnect battery and remove steering wheel airbag (two screws from the rear) then everything is pretty obvious!
:y Cheers Mark. Not having tinkered with the steering wheel was a bit dubious regarding airbag and airbag light [smiley=tekst-toppie.gif]
Just in case you're unlucky to be as dopey as I was, the yellow connectors to the airbag squib with 'warning' all over it, they do disconnect by prising the clip up with flatbed screwdriver.
Keith
OK thanks for the tip :y
Tis best to leave the car disconected from the Battery for about 5 odd mins to let it discharge itself.
Do you know the way to disconnect the battery ? do it within 15 seconds of turning the ign off and removing the key or you will set your alarm off
