Omega Help Area => Omega Electrical and Audio Help => Topic started by: Timbuk on 21 August 2007, 21:43:02
Title: Bose... No sound
Post by: Timbuk on 21 August 2007, 21:43:02
On the Elite i have just bought one of the problems was the Head unit was dead, fixed that problem today as it was unplugged  ::) but now i have no sound at all, everything else is working just no noise, any ideas  :question
Title: Re: Bose... No sound
Post by: VXL V6 on 21 August 2007, 22:11:24
Need to prove if it's the speaker outputs off the head unit, the cabling, the speakers or the Bose.
I'd try a known good speaker connected to the headunit with all others disconnected, at least then you can prove the Head Unit is good for starters.
I've seen a similar problem on a Cavalier years ago and it turned out to be a short on both speaker wires to earth as they went through to the front door which then brought down all of the speaker outputs on the Head Unit
HTH
Post by: Danny on 21 August 2007, 23:14:43
no sound even from traffic master?
Post by: Timbuk on 22 August 2007, 09:12:50
Nope  :-/
Post by: markey mark on 22 August 2007, 11:48:02
presume you have checked the bose fuse ??  ::)
Post by: sounds2k on 22 August 2007, 14:52:08
does the head unit actually state "bose" on the cassette door? As if not, it will be sending high level signals through the speaker outputs and the bose amplifier will trip as it expects to be fed line level signals ... assuming the elite is pre or mini-facelift ...
Post by: Marks DTM Calib on 22 August 2007, 16:49:15
DO check the amp fuse, although I would hope thats already been done as there is a reminder permanently scrolling past on your signature!
Post by: Timbuk on 22 August 2007, 20:15:48
Errrrr.... Wheres that then :question, checked fuse no 6 and the one on the back of the head unit, is there another  :question
Post by: VXL V6 on 22 August 2007, 20:51:32
Sorry, didn't realise it was line level from the head unit, thought it was a seperate set of channels for the BOSE. Ignore my earlier advice! ;D
I'll get me coat
 :-X :-X :-X
Post by: davlad22 on 23 August 2007, 02:25:45
Given that the HU was dead/unplugged, has somebody been hacking around with it then???
...and it's a facelift isn't it?
Post by: TheBoy on 23 August 2007, 20:58:24
Check the amp is still there :P
;D ;D ;D
Post by: BrokenAgain on 28 August 2007, 07:41:07
Unlikely to be the following, (you'd probably hear something at least), but It could be both of the balance pots have dry joints.
i.e. the one that controls the left channel is acting as if the balance is all the way right and vise versa for the right channel.
See my post in the CDR 2005 thread....
http://www.omegaowners.com/forum/YaBB.pl?num=1187004803
Post by: TheBoy on 28 August 2007, 17:04:04
Timbuk should have updated this post. It turns out the amp was missing ;D
Post by: Timbuk on 28 August 2007, 17:54:13
Well i sort of did in another thread  :-[
Post by: BrokenAgain on 29 August 2007, 22:15:27
Ok, well at least you know whats wrong with it now.   Hope you can find an amp at a scrap yard or breakers  :)
