Omega Help Area => Omega Electrical and Audio Help => Topic started by: Jay w on 15 October 2007, 22:16:31
Title: blaupunkt multichanger code
Post by: Jay w on 15 October 2007, 22:16:31
not mine, my friend with a P reg vectra CDX, i would imagine it is the same set up as a similar model Omega.
He has the radio code but not the multichanger one, i know it is a dealer thing but aside form the reg docs do they need anthing off the multichanger?
if so how the hell do you get it out of the glovebox???
Title: Re: blaupunkt multichanger code
Post by: VXL V6 on 15 October 2007, 22:33:35
To get the autochanger out of the glovebox on a Vectra you need to remove the glove box - Two screws on the underside (top of the footwell if you see what I mean) and two at the top of the glovebox with the lid opened then gently pull the whole box forwards, BE VERY CAREFUL OF THE AUTOCHANGER CABLE on the r/h side as you remove the glovebox
Once out (The trafficmaster will probably fall out as well because it's aerial is taped to the top of the box) there is a screw either side to release the autochanger and the cable needs to be gently unplugged.
Finally you can get the unit out to read the serial number!!!!
A number of outlets are able to get the codes from Blaupunkt but if you're struggling i'll dig out the number of a dealer I know.
Post by: Entwood on 15 October 2007, 22:46:09
not sure if this site will help .. did with my radio code .. not sure about multichangers ...
http://www.31bubblegum.proboards54.com/index.cgi?board=here
Post by: Jay w on 15 October 2007, 22:46:50
cheers  :y
Post by: TheBoy on 16 October 2007, 20:31:04
Just the V5 needed for the carpass...
Post by: Jay w on 16 October 2007, 22:36:43
got the glovebox out today took a fair time as we didnt want to damage everything.........
got the serial number, putting it all back together and noticed a leather binder under the passenger seat, looked inside and found all the instructions and the car pass >:( >:(
i slapped him soooo hard
Post by: markey mark on 18 October 2007, 20:17:40
 ;D ;D ;D
